I7 920 Motherboard Help
Last response: in Memory
Just picked up an i7 920 wanted to know which is best motherboard and cooler i should get to go with this? I plan i doing some decent overclocking
More about : 920 motherboard
Pick an ASUS mobo. There are many goods options. It depends on the money you want to spend:
ASUS P6T: Good mobo.(Don't buy the SE version). Overclocks very well. It works properly. It's a good choice. The cheaper one.
ASUS P6TD DELUXE: It's a deluxe. It has more features than the other. It's newer too.
ASUS P6X58D PREMIUM: Impressive mobo. I would choose this if it was for me. No-native support for USB3.0 and SATA-600.
ASUS RAMPAGE III EXTREME: It's not out yet. It's a monster. Probably you can get it next month. If you have a lot of money and you don't minf to wait a while...The most expensive one.
Related ressources
- I7 920 motherboard upgrade help !!! - Forum
- Need help with a motherboard pick for an i7 920 . - Forum
- I7 920 60C idle and 95 under heavy load, help ! - Forum
- I7 920 motherboard - Forum
- I7 920 Gaming Computer - Motherboard + Case advice! - Forum
All of them are good overclocking boards. Anyway, the rampage is better than the P6x58D which is better than the P6TD which is better than the P6T.
But with the P6T you can reach 4Ghz (if your 920 D0 is a good one)
I prefer ASUS, but if you want a Gigabyte, look at these options:
Gigabyte GA-X58A-UD7 Intel X58+ICH10R ATX LGA1366 Triple-DDR3: 300€ more or less. A great mobo. The best from Gigabyte.
http://www.gigabyte.com.tw/Products/Motherboard/Product...
Gigabyte GA-X58A-UD5 ATX Intel X58+ICH10R USB3 LGA1366 Triple-DDR3 SATA3: 260€. Works very well and it has plenty of features.
Gigabyte GA-X58A-UD3R Intel X58+ICH10R USB3 LGA1366 Triple-DDR3 SATA3: 190€. The cheaper one, but good enough to overclock well the system.
Henry Chinaski said:
Pick an ASUS mobo. There are many goods options. It depends on the money you want to spend:ASUS P6T: Good mobo.(Don't buy the SE version). Overclocks very well. It works properly. It's a good choice. The cheaper one.
I just built my gaming computer about 2 weeks ago. i put a asus p6t mobo in it. It runs fine im very happy with it. I put corsair memory in it DDR3 it runs at 1600 but the mobo only runs at 1066 i think. you have to go into the BIOS and change it its really easy. i would agree the p6ts are great.
If you can pay the extra cost, go for the P6X58D PREMIUM.
There are some very good coolers in the market. I like the more the two following ones:
- NOCTUA NH-D14
- PROLIMATECH MEGAHALEMS + 2xSILVERSTONE FM123 fans (or 2xYate Loon D12SH-12 fans)
Anyway, here you have a comparative:
http://benchmarkreviews.com/index.php?option=com_conten...
This web is a good one too. Note that the cooler list is for the 775, but it's useful anyway:
http://www.frostytech.com/top5heatsinks.cfm
- NOCTUA NH-D14
I use the 1200. All fans at lowest setting except the top one. It is at medium speed. It was an easy build, lots of room and no wires showing. I chose it to be able to use the CP-850 p.s. They are made for each other. The p.s. was reasonable in price and is totally quiet under full load. After 10 hours of Prime 95 Blend no core rose over 69c.
Only thing is if you use the Noctua NH-D14 you will have to mod the side panel fan bracket as the cooler will hit it. The cooler is big.
Here you have a very recent review about the Noctua NH-14D.
http://www.youtube.com/watch?v=EKHRPJfZ5Y8
CM 932 or Antec 1200? . Both are very good cases:
CM 932: http://www.youtube.com/watch?v=BvsG7AH-9c0
Antec 1200: http://www.youtube.com/watch?v=0j3MNAQLuIQ
I would recommend you another 2 towers:
CM atcs 840: http://www.youtube.com/watch?v=r8_1cQkYTO4
LIAN LI PC-X1000B: http://www.youtube.com/watch?v=GqZM4kPnZPY (very very expensive but, in my opinion, the best for air cooling)
Choose the one you like best.
About the power supply, that Antec CP850 is a very good option for the Antec case.
http://www.hardwaresecrets.com/article/736
Anyway, I would choose the CORSAIR HX850 psu:
http://www.hardwaresecrets.com/article/741
On the 1200 you remove the side panels and undo 4 thumb screws on each side. Then the bay slides forward and out provided your wiring has the slack. This is the same method for cleaning the filters that sit at the front of each removable module. Each module could hold 3 drives. To facilitate filter cleaning some users leave the thumb screws off the sides of the cadges behind the solid non windowed panel. I do not find it much of a problem to remove both sides to get at the thumb screws. My filters get cleaned a few times a year so its no big thing for me.
If you plan to O.C. the stock cooler will not be adequate. T.R.U.E 120 or the new Viper is good and so are a good selection of others. NOCTUA 14 is what I chose as I consider it the best. I suggest you read the reviews and comparisons of anything you think you might buy. I spent quite some time reading and in forums before choosing.
Related ressources:
- ForumPlease help with Overclocking i7 920 and RAM on DX58SO
- ForumCore i5 3470 or Core i7 920 ?
- ForumI7 920 D0 vs Xeon w3520 ? Please help .
- ForumNeed motherboard advice for i7 920
- ForumI7 920 Motherboards HELP !!!!
- ForumFS [Feeler] - i7 920 /GTX 295 system
- ForumPls help choose RAM to OC i7 920
- ForumNoob needs help getting i7 920 stable at 4.0GHz
- ForumI7 920 system locking up
- ForumI7 920 Only one thread - no hyper-threading - Please help
- ForumHelp updating BIOS
- ForumHi problems with am asus p5q motherboard
- ForumRepair dead motherboard
- ForumDo they make motherboard audio to case front pannel cable extenders?
- ForumMotherboard recommendations
- More resources
Read discussions in other Memory categories
