My xbox hard drive work after i put it in my laptop, can someone help?
mister-hi
When i rang microsoft they said they said the hard drive can't be used any more cause i put in my laptop, can someone help me extract all my saves, download content and profiles on this hard drive cause i really don't want to start over. i have xplorer360 i just don't know how to tell what files what. Can someone please help? Thanks
plasmastorm
726
if you installed any data on the drive while it was in the laptop, changed the partition structure (like a format) or installed windows oe anything really other than put in in the machine and then take it out again your data is almost certainly gone for good.
Try the hdd in the xbox and if it says it needs to format it to use it then at least you dont have to buy another one.
Other than that your data is gone.
