During system restore the power got shut off now how can i get system to load?
now it wont load windows at all. any one have any ideas? i dont want to format and reinstall. trying so hard not to...
1 answer Last reply
More about during system restore power shut system load
  1. You could do a repair install using the original XP installation disk (you'll need the product activation code from the box). Insert the CD, boot from the the CD, follow the screens to repair the windows installation on your computer. After you have repaired it, download/install SP3 (if the CD did not show your version as Windows XP SP3). Then you'll have to re-activate it to download and install all the updates from the MS/Windows update website.
System Restore Power Format Windows XP
