Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > XFX 5870 poss problem?
Forum Graphic & Displays : Graphics Cards - XFX 5870 poss problem?
wonder if a 5870 owner can help me out, during building my new pc i forgot to connect the 12v atx so when powering up the pc wouldnt boot, i noticed this after about 5 mins and sorted out. but when the pc was powering up but not booting i noticed that the XFX 5870 fans blew quite hard, now ive connected the 12v atx on the mobo and the new pc boots fine but the 5870's fans dont blow very hard at all anymore.
is this normal will the fans kick in properly when its under load?
cheers
Sponsored Links
The fans are automated, basically they spin faster then the temeratures get higher.
To get the temps of your card, download Hard-Ware Monitor from CPUID. This'll let you take the temperatures of your card.
Acceptable temps are below 80C.
Reply to shadow187
- 0 +
cheers shadow, guess cause i didnt have the mobo connected properly when the power came on the XFX fans came on full blast but now its operating normal.
Reply to Kiring
On boot, they spin up full speed momentarily. But the fan speed is contrlloled by the GPU temperature. The hotter your card gets, the faster the fan spins. In normal browsing the fan should be at the lowest setting and relatively quiet. But once you start playing games the fan will kick up. If the fan sounds like a typhoon all the times, only then do you have a problem.
------------------------------ <Gaming PC> | Cosmos 1000 Case | Zalman 850W PSU | EVGA X58 3XSLI | i7 920 OCed to 3.3GHz Stock Voltage/Fan | 6GB OCZ Platinum 1600 | Sapphire HD5870 | 2x Samsung 2343 (2048 x 1152) + 1x Samsung 2333HD (1080p) | 4x 1TB HDs in RAID 5 | Windows 7 Build 7100
Reply to Zirbmonkey
There are 1298 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
