Solved
1100T OC BSOD with low temps....Help?
System Specs:
CPU: AMD Phenom II X6 1100T Processor, Black Edition 4.1Ghz
CPU Cooler: Cooler Master V8 Nickel Plated Copper Base Aluminum Fins 8 Heatpipes
Case: Cooler Master HAF X Full Tower w/ SuperSpeed USB 3.0 w/ Window w/ Black Interior ATX Case)
HDDs: Seagate Barracuda XT 2 TB 7200RPM SATA 6 Gb/s 64MB Cache 3.5 Inch Internal Bare Drive ST32000641AS
Seagate Barracuda Green 2TB SATA 6Gb/s 64MB Cache 3.5-Inch Internal Bare Drive ST2000DL003
Graphics Card: MSI Radeon HD 6870 1 GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity R6870 Twin Frozr II
Power Supply: X4 Series 850W Atx Ps
Motherboard: ASUS Sabertooth 990FX - AM3+ - TUF Series
RAM: 2x Corsair XMS3 4GB PC12800 DDR3 1600MHz 4096MB (9-9-9-24-2T) 1.65v
Ambient Room Temp is around 48 degrees F. (House has terrible insulation. haha)
Ok. I tried overclocking last night (First Attempt), I followed the AMD BE guide here on Tom's. Well I kept increasing the multiplier up til I hit 4.1Ghz (My ultimate goal is a stable 365/24/7 4.3Ghz) but I figured I would see how stable my machine is at 4.1 first.
I booted, everything went good.
Checked CPU-Z. Checked Core Temps. Looked good (I think)
Then started Prime 95 Blend test.
I sat and watched the temps, using Core Temps and the AI Suite II. At no point while I watched it, did it go over 34C. I watched for a good 30 min and it seemed to be staying right around 34C.
I left it on overnight and woke up to a restarted comp. My comp BSOD sometime during the Prime 95 test.
I really don't think that it overheated, it seemed to be running really cool. Also, I checked the results.txt from Prime and saw some errors. What could these be from?
So I am asking for help. What should I do now? What are those errors for? Any help is appreciated.
Here is a screen shot of CPU-Z and Core Temps:
Just in case you can't see the screen:
Core Voltage: 1.380 V
Core Speed: 4113.8 MHz
Multiplier: x 20.5
Bus Speed: 200.7 MHz
Here is the log from Prime95:
[Wed Jan 04 21:23:14 2012]
FATAL ERROR: Rounding was 4096, expected less than 0.4
Hardware failure detected, consult stress.txt file.
FATAL ERROR: Rounding was 0.5, expected less than 0.4
[Wed Jan 04 21:36:51 2012]
Self-test 640K passed!
[Wed Jan 04 21:52:04 2012]
Self-test 8K passed!
[Wed Jan 04 22:37:40 2012]
FATAL ERROR: Rounding was 1024, expected less than 0.4
16 answers Last reply Best Answer
More about 1100t bsod temps help
  1. Best answer
    Core Voltage: 1.380V need up to 1.4v - 1.45 depend which can get stable and i think BSOD 0x00000000124
    Ok. I think right now I have it set to Auto? I think that's what the guide said, leave everything on auto except multiplier?
    But I will try that as soon as I get home.
    (For changing the Core Voltage, I know to start at 1.4v and work my way up, but should I use the first stable voltage....or keep increasing the voltage to the maximum stable voltage?)
    Sorry, I forgot to write down the BSOD number...... :pfff:
    For the Prime95 errors...Do you know what is causing those?
    I was searching other threads and it seems like people automatically think it's the RAM. SO when I get home I will also run memtest (but I really think my RAM is ok).
    Are there any other stress test software you would suggest?
    (Like I said, first time overclocking, sorry for the lack of knowledge)
  3. your voltage CPU need more at 4.1ghz and don't let under auto like voltage CPU / RAM and keep NB at 2000 and other setting like Cool n Quite , PCIE spectrum, C1E , turbo from enabled to disabled :)
  4. Yea. That is the guide I was using. Must not have read it in depth enough. haha.
    I have the RAM set to the manual factory settings. I disabled all of those things. IDK if I touched the NB though and I am sure that I have the voltage on auto.
    Well 8 more hours at work til I can go home and fix this. :/
    So I will
    1. Up the core voltage to between 1.4-1.45
    2. Make sure that NB is manual at 2000
    3. run memtest
    4. try to stress test this again.
    Thank you for the help. :)
  5. Best answer selected by sardonicjester.
  6. good luck
  7. Thanks. I will update this post tomorrow with my results.
  8. Six PhII cores at 4GHz is a GFLOPin' machine. Doing it at less than 1.4v is really, really good, but not unheard of.
    CPUz might be a little misleading on individual core voltage so don't be 100% certain of that 1.38v. I feel a bit more comfortable using the Asus Probe utility for temps and voltage. Actually, I use 3 utilities and triangulate :lol: which seems to generally point toward Probe readings
    Assuming you disabled Turbo, have qualified memory and left LLC on Auto, I would suggest dropping your CPU multiplier back to 4GHz and taking manual control of your voltages. I would also experiment a bit with different LLC levels (looks like you are at the extreme level, anyway).
    Tinker with your NB volts and multiplier. You should be able to run 2400MHz IMC/NB close to stock volts. For each 10% you increase the IMC/NB speed, memory bandwidth is increased 3-4% and latency is reduced 3-4%. 'Enthusiasts' take the NB beyond 3000MHz, but there tends to be a points of diminishing return beyond 25-2600MHz.
    Make sure you save a stock profile -- then save your OC profiles, too.
    edit __ it's your HT link speed at 2000MHz (no OC'ing)
    Yea..... a lot of lingo there I don't fully understand. haha.
    But what you are saying is:
    Push multiplier back to 4.0 and increase core voltage.
    And raise NB to around 2400-3000MHz and leave HT at 2000? hahaha.
    Yea, I really don't understand much of that, sorry. :whistle:
  10. Ok. well read up on LLC and it doesn't sound like there is a definitive answer for whether or not to use it.
    http://www.overclock.net/t/556097/cpu-llc
    It sounds like:
    If i raise my Core voltage to anything above 1.38, then LLC may cause surge spikes over the 1.45 limit....in turn damaging my CPU.
    Maybe I am misunderstanding this? what levels can you set LLC to? (other than auto and off)
    EDIT:
    SO,
    Let's say I up my core voltage to 1.42 and my NB to 2500. What would be an appropriate LLC level to maintain stability and not risk excessively high spikes?
  11. Carefully read and understand Chapter 3 of your motherboard manual. With regard to the NB/IMC Freq and HT Link speed, see page 3-9.
    Quote:
    CPU/NB Load Line Calibration [Auto]
    Allows you to select the CPU/NB Load-Line mode.
    Configuration options: [Auto] [Regular] [High] [Extreme]
    From page 3-11
    If you are uncomfortable with LLC, leave the setting on 'Auto'. The chip is designed to increase voltage to individual cores while raising their multipliers - running 3 cores at 1.45v with an increase in the multiplier to 18.5x from stock 16.5x
    When you raised the multiplier from stock 16.5x to 20.5x, you raised the potential Turbo to 22.5x (or 4.3GHz) across 3 cores (if you have not disabled Turbo).
    VDroop is not a bad thing if properly managed, and that is what LLC helps you do by smoothing the volt transition.
    You may also use the offset voltage settings for further refinement.
  12. Ok, thanks.
    Yea, I think I will leave LLC on auto. I read through that section and still don't fully understand it.
    Quote:
    "CPU Load-line Calibration [Auto]
    Load-line is defined by Intel VRM spec and affects CPU voltage. The CPU working voltage will decrease proportionally to CPU loading. Higher Load-line calibration would get higher voltage and better overclocking performance, but increase the CPU and VRM thermal. This item allows you to adjust the voltage range from the following percentages to boost the system performance:
    0% (Regular), 25% (Medium), 50% (High), 75% (Ultra High) and 100% (Extreme).
    Configuration options: [Auto] [Regular] [Medium] [High] [Ultra High] [Extreme]"
    This confuses me. This means that under load, my Core voltage and multiplier will increase from what I already set it at correct?
    Saying I set my core voltage to 1.42 wouldn't this be dangerous even if I picked the lowest 25%? That would push it over the factory range limit of 1.45v.
    (I did disable turbo. I disabled all of the "features" according to the guide)
    Im sorry. I am just having trouble catching on to the whole LLC, VDroop, offset concept. :pfff:
  13. Well I think I found a pretty stable OC.
    Core Voltage: 1.428 V
    Core Speed: 4113.6
    Multiplier: x20.5
    Bus Speed: 200.7
    HT Link: 2006.6
    NB: 2207.5
    Ran for 2 hours. no errors. no BSOD. looks nice. :wahoo:
    (I wanted to go up to 4.3, but in my attempts to go up even 0.1 more, Windows wouldn't even start. So it looks like 4.1 is where I am to stay)
    Thanks again for you help guys. :bounce:
  14. Funny after reading some of this, It actually helped me with a friends Asus board, Other then that.
    I wanted to point out something tho, With your Vcore at 1.428v is low for 4.1ghz, So saying that you could probably do 4.2ghz at around 1.45 - 1.5v. AMD says the max vcore for the 1100T is 1.55v, So your well with in the safe zone, but remember the max temp on these is 62c.
    You can experiment with LLC just watch the volts while stress testing the CPU, On my ASRock 970 Extreme3 with out LLC my volts would drop to low and I couldn't even keep 4.0ghz unless I wanted to idle really hot trying to compensate without LLC with volts at 1.5v and not stable at 4ghz is kinda crazy.
    Now when I enabled LLC on this mobo I can now pull 4.2 - 4.3ghz with my volts at 1.45v and LLC will raise it to 1.502v the highest I seen running prime95. I now idle at 29c just surfing the web on the h100 and 53c full load. Play with the LLC, it shouldn't hurt the CPU at all, just watch he volts, you could probably hit your goal of 4.3ghz. Just don't go more than 1.55V on the CPU.
    Also The CPU-NB you do want to raise, 2500mhz+ would be a good place to start with DDR3 1600mhz, you will see a good performance increase with that up, the HT link keep it at 2000 - 2200mhz.
  15. LLC - High or Ultra, it will help hold stable voltages needed at higher clocks.
    CPU/NB 2200-2600mhz should be on the money at 1.28~1.30v on the CPU/NB.
AMD Overclocking
