Tom's Hardware > Forum > Graphic & Displays > ATI > HIS 4830 Heat Problems Need Help
Forum Graphic & Displays : ATI - HIS 4830 Heat Problems Need Help
My HIS 4830 has been going up into the 100+C temp range while playing games such as CoD4/5 and some others. Even though my card hits over 100C it doesn't slow down, crash or nothing. My card seems to idle normally at 33Ccore 38Cvram but once I turn on CoD4 or something it heats up to 100+ almost instantly. I was wondering if the HSF could be not seated right on the card.
Sponsored Links
Max out the fan speed.You can also check whether HSF is properly seated or not.Clean all the dust (If any).
Other thing to be taken care of is case airflow.
Reply to shubham1401
My card you can't control the fan speed unfortunately.
Reply to diablo2king
Use catalyst control center, it will allow you to manually control the speed of the fan in the ATI Overdrive section. You also want to boost the airflow in your case, even the worst cooler should hold the chip at safe temperatures for a few minutes. Run furmark and see if your heat spikes, also make sure to watch the case temp, if that starts rising rapidly then its a problem with case airflow not card airflow.
Reply to hunter315
After cleaning the area around the fan, I believe that you can use rivatuner to raise the fan speed. If that doesn't seem to help, you might have to reseat the cooling system with fresh paste.
Reply to soundefx
No I can't control the fan at all. Here's a picture of my CCC.
http://i213.photobucket.com/albums/cc75/diablo2king/nofancontroler-1.png
I also ran FurMark and my min temp was 45C and my max temp was 91C
http://i213.photobucket.com/albums/cc75/diablo2king/furmark_000000-1.jpg
Message edited by diablo2king on 10-16-2009 at 09:18:50 PM
There are 1228 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
