Tom's Hardware > Forum > Homebuilt Systems > New System Build > [Solved] Will all this work together? Please Help.
Forum Homebuilt Systems : New System Build - [Solved] Will all this work together? Please Help.
Best answer from SAINT19.
I'll be buying this in couple weeks, and just wondering if all this will work together.
Please help me out. I think it will, but I always want a second opinion.
Thank you.
CPU
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
http://www.newegg.com/Product/Prod [...] 6819103674
CPU Fan.
COOLER MASTER Intel Core i7 compatible V8
http://www.newegg.com/Product/Prod [...] 6835103055
GPU
SAPPHIRE 100281SR Radeon HD 5870
http://www.newegg.com/Product/Prod [...] 6814102856
PSU
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V
http://www.newegg.com/Product/Prod [...] 6817139006
MOBO
MSI 790FX-GD70 AM3 AMD 790FX
http://www.newegg.com/Product/Prod [...] 6813130223
RAM
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
http://www.newegg.com/Product/Prod [...] 6820231190
CASE
COOLER MASTER RC-690-KKN1-GP
http://www.newegg.com/Product/Prod [...] 6811119137
DVD
LG DVD Burner Black SATA Model GH22NS50 - OEM
http://www.newegg.com/Product/Prod [...] 6827136167
HDD
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM
http://www.newegg.com/Product/Prod [...] 6822152181
Please Let me know. And if anything can be better but at not too much more $$.
THANKS.
Sponsored Links
The CPU FAN isn't support the 955. And add another HDD.
------------------------------ If you like my answer, select me as the best answer.
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.". Albert Einstein.
Reply to SAINT19
Thank you Saint19.
What would be a good CPU fan for 955? up to 70$ would be great.
Reply to jvwash
Reply to SAINT19
There are 1275 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
