Hi,
I have an i5 750 on a Gigabyte P55-UD3 board and am overclocking the BCLK. Up to 145 (stock 133) the multiplier will move from 9x up to 24x depending on the processor load. However if I set the BCLK above this (say 150) the multiplier stays above 20x up to 24x.
This means that it always runs hotter (so my coolers fan is always audible, as opposed to silent at idle) and it uses more power. Is there any reason why it would behave like this and is there any way that you can set it to keep the power saving options even if you set the BCLK higher than 145 with an i5-750?
