Sign-in / Sign-up
Problem to run porteble harddisk
  • Hard Drives
  • Laptops
  • Connection
  • Storage
Last response: in Storage
August 7, 2011 12:21:56 PM
when i connect my porteble hard disk with laptop the hard disks light is blinking but the hard disk will not run or saw in my computer how to solve it please help...
More about : problem run porteble harddisk
a b D Laptop
a c 415 G Storage
August 7, 2011 3:47:31 PM
Is this a new drive? If so, you need to partition and format it before you can use it:
Click "Start" --> right-click "Computer" and select "Manage".
Click "Disk Management" in the left pane.
Scroll down to the BOTTOM of the MIDDLE pane.
You should see your new disk there with a label such as "Disk 1" or "Disk 2", etc. Right-click on the label in order to create a new volume (which partitions the drive) and then again to format it.
Once it's formatted Windows will assign the next available drive letter to it and then it will appear in Windows Explorer.
m
l
