My apologies for not reading enough before posting a few weeks back. Hopefully this one will make more sense and the links will work.
APPROXIMATE PURCHASE DATE: Soon after Windows 7 is released
BUDGET RANGE: Open ended
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: internet with loads of tabs open, java apps, listening to music, streaming movies, maybe disk movies, ( no games )
PARTS NOT REQUIRED: Monitors ( 2 x DELL 2209WA 22-inch ) Speakers ( Audioengine A2's )
PREFERRED WEBSITE(S) FOR PARTS: newegg.com seems to be popular, Microcenter brick and mortar not an option
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: Intel CPU
OVERCLOCKING: No / Maybe
SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1680x1050
ADDITIONAL COMMENTS: I would like a quiet, stable PC. From this parts list I could change out the motherboard, CPU, and ram to configure i5 750, i7 860, or i7 920.
I like the case, power ( I think 620W is enough ) and GPU.
Changing the CPU to the i7 860 is $90 more. Changing the rig to i7 920 would add $270 since board and ram are more expensive. I believe the i5 750 is plenty for my needs but might spend $90 more for the i7 860.
Not sure if I need a CPU cooler or not. Some that fit the 1156 socket are coming out now. Might not get into OC. Has anyone used Indigo Xtreme instead of paste ?
I chose 1333 1.5 v ram. From what I've read this should be the stock speed of this board although it shows DDR3 2200(O.C.)/1600/1333/1066. Any reason to change to 1600 ram ?
Onboard sound is fine.
Don't need storage beyond the SSD. However I am curious. Since it's important for me to have a running machine, is it possible to buy another SSD to use as a ghosted image backup ? Doesn't need to be this large. It would be nice to have another SSD ready to install in case of failure. I think they make a 5 1/4 drive bay to plug in 2 SSD's ? Today if I have problems I use my laptop instead.
Parts list
ASUS P7P55D PRO LGA 1156 Intel P55 ATX Intel Motherboard Retail $170
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131405
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processo Retail $200
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
2 X G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Retail $90 X 2 = $180
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231276
CORSAIR CMPSU-620HX 620W ATX12V v2.2 and EPS12V 2.91 SLI CrossFire 80 PLUS Retail $150
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139002
HIS H465PS512P Radeon HD 4650 512MB 128-bit GDDR2 PCI Express 2.0 x16 HDCP Retail $63
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161274
Intel X25-M SSDSA2MH160G2R5 2.5" 160GB SATA II MLC Internal Solid state disk (SSD) Retail $590
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167024
LIAN LI PC-7F Black Aluminum ATX Mid Tower Computer Case - Retail $120
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112194
PLEXTOR Black 24X DVD+R 8X DVD+RW 12X DVD+......... Retail $53
http://www.newegg.com/Product/Product.aspx?Item=N82E16827249051
That's about $1600.
I hope the links work this time.
Thanks in advance. What an informative board.
Parts list
That's about $1600.
