Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Problems with Gigabyte GeForce 8400 GS 256MB
Forum Graphic & Displays : Graphics Cards - Problems with Gigabyte GeForce 8400 GS 256MB
I got this Gigabyte GeForce 8400 GS 256MB.......... bt it seems dat no matter what game i play my pc hangs a lot!!! Even CS-1.6 i cant get 100 fps due 2 such lags.... so while playing CS i always keep my task manager open. which cuts da hang bt still lags a lot... Plz help me wid dis Problem.... MY PC specification are, MSI 945GCM7 mother board, Intel DUEL-CORE 2.25 processor Gigabyte GeForce 8400 GS 256MB PCI, and 80 GB H.D.D! PLZ help me wid this problem!!!
Sponsored Links
did your pc hang only when playing games or does it also hang when doing something else like watching movie? but 8400GS never made for serious gaming. can you post your full spec?
Reply to renz496
Nope it only hangs on playing games.......... :( but yes sum-times i face this pixels problem which goes away after restarting my PC..... Nd CounterStirke 1.6 doesnt require high graphics bt still dis low configured games lags... which really makes me mad.. Will this help u to find a solution for my prob?? PLZ reply!!
Reply to Alpha_Arif
yeah you are bottlenecking your computer somewhere, what is your RAM/FSB speed. your CPU might also be bottlenecking. CPU is much more important for gaming than people give it credit. CS 1.6 is so easy to run, i can run it high detail on my four year old comp with integrated graphics 1GB of PC-3200 2.2GHz single core
Reply to jms31207
- 0 +
what about your cpu & graphic card temp? sometimes overheating may cause the game to hang or system emergency shut down. if thats not the case you can try updating your graphic driver but i doubt that will solve your problem. btw if you really want to play games it is better to get more powerful card like ATi HD4650/HD4670. they are pretty cheap right now
Reply to renz496
Hmmmmmm i guess there is no solution 2 my problem... still thnx guyz 4 helping me out!!!! ND im using 2 GB ram...........
Reply to Alpha_Arif
There are 630 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
