New build 1000$ gaming PC, help!
Hi, i'd like some advise on a new build for a 1000$ gaming PC (budjet can be exceeded if needed). I'm starting from scratch so i need all the parts (monitor excluded). I'm looking for a PC that i can keep for 4-5 years. I'll probably buy the parts in one month on newegg.ca (i live in canada). I'd prefer intel based builds.
Any advice is welcome!
2 answers Last reply
More about build 1000 gaming help
  1. You forgot to post monitor size and also what type of games you play
    this is a wish list i created on new egg a while back just took some more expensive parts out but all in all its a nice rig should last u a while
    Thermaltake V9 Black Edition ATX Computer Gaming Chassis with Dual Oversized 230mm Ultra-Silent Cooling Fans VJ400G1N2Z Mid ... - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811133074 $94.99
    HITACHI 0A38016 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822145233 $79.99
    XFX HD-489A-ZDFC Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814150359 $194.99
    CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ... - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006 $119.99
    OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3G1600LV6GK - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16820227365 $129.99
    ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16813131365 $289.99
    Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202 $279.99
    XIGMATEK Intel Core i7 compatible Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029 $44.98
    LG DVD Burner Black SATA Model GH22NS50 - OEM
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827136167 $28.99
    Total=$1,263.90
    you could go with the i5 on th 1166 socket but personally i feel that it limits your expansion later on
    the case i like because it has alot of air flow with the 23cm fans on the side and top so it will keep everything cool but you can go with a cheaper one
    the power supply you can go cheaper too but it helps when you would like to get the 4890 in CF later on which will extend the life of the system even tho its a beast now
    and the hard drive can be smaller to save money but if u need it its there
  2. http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
    I suggest you get this samsung f3 hdd instead of the hitachi one. It's faster and only 1 platter of 500 GB, hence less heat produced by the drive
New Build Gaming New Build Systems Product
