I am putting together my new system and I am getting conflicting information from the manufacturers of the Antec New TP-750 PSU and the Cooler Master Storm Scout. I am installing the PSU into the case but am trying to figure out if the exhaust fan for the PSU is supposed to face up into the case or down and out the vent in the bottom. Antec said facing up, but when I called Cooler Master they said facing down. I will have two XFX 4850 GPU's approximately 3-4 inches above the PSU if the fan is facing upwards. If the fan points down, then there is about a half inch of room between the floor and the case. Would this be enough space to vent the heat out of the bottom properly? Does the PSU even put out enough heat to really matter if it is up or down? Which is a better way to go? PSU fan up or down??
I would go with antec on this one, the fan will barely run so it wont affect the air flow much which is what cooler master is concerned about as the fan is an intake and would disrupt the hot air rising to exhaust fans mentality. Most antec cases have bottom mounted PSUs so i think its pretty safe to assume that even having the fan sucking in on the bottom, with a good efficient PSU, wont need to draw very much air in so it wont affect airflow much.
Intake through the bottom means cooler air will get in the PSU, meaning the PSU runs cooler, this way it also won't obstruct the airflow of the other fans in the case.
------------------------------CPU: Intel Core i7 920 @3.2Ghz, MOBO: Asus P6T SE, RAM: 3x 2gb OCZ Platinum OCZ3P1600LV6GK, GPU: Sapphire HD 5870, PSU: Corsair HX520W, HDD: Seagate ST31000528AS 1Tb 32mb, COOLER: Scythe Mugen (S775 version), CASE: Coolermaster CM690
Reply to Gulli
You have the PSU airflow backwards, it would be pulling cold air from the bottom and blowing it out the back if it were facing down. Thats ideal conditions for cooling a PSU if there is enough dust free clearance below. The storm scout has a grill there to give you that option, many bottom mount PSU cases require modding to do it (like antecs).
In antec cases the PSU pulling air from the central chamber and out the back creates airflow that helps pull the cold air from the front and side vents to the GPU without the optional side fan mounted. The GPU almost divides the case into a dual flow system with one front fan send air to the CPU and out the back/top and the other pushing air to the PSU and GPU then out the back.
By experimenting with different fan locations and speeds you may find some airflow setups help you cool different components better than others. On the storm scout that would include trying the PSU in both facings.
With 2 GPUs you may want to put an optional side fan on to blow cold air from the side grill straight to the GPUs and then face the PSU fan down to pull cold air from below. You should also consider adding an optional fan to the top to blow the hot air up and out faster.
Message edited by dndhatcher on 10-03-2009 at 03:33:45 AM
