Which motherboard to use with XPS 420 parts?
Hey there, I've decided to try and build a new PC using parts from an xps 420 dell I have (Core 2 quad, 3GB DDR2 Ram, ATI 2400). This is my first time building my own PC so I'm not too sure on what parts I'd need to purchase. Especially the motherboard, I had this one in mind
http://www.gigabyte.us/Products/Motherboard/Products_Overview.aspx?ProductID=2665
though I can't seem to find a place to purchase it. Does anyone know of another motherboard that's just as good?
1 answer Last reply
More about which motherboard parts
  1. 1. The X38 is old tech. Get a P45. Generally, I recommend the P45-UD3L.
    2. List full specs including PSU,etc.
    3. You will need:
    * A new motherboard
    * Possibly a retail copy of your OS as the OEM copy won't probably activate.
    * Will need a GPU
    * You may need a new PSU.
    * You will probably want a new case as well.
    4. All of these items mentioned can be bought here: http://www.newegg.com/
Motherboards XPS
