Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > No sound when outputting to HDTV from PC.
Forum Graphic & Displays : TV/Video Cards - No sound when outputting to HDTV from PC.
Hi all, after hours of failure i've resorted to making this account.
I'm trying to connect my PC to my Samsung HDTV, but can't get audio.
I'm using Realtek HD onboard soundcard with my ALiveNF6G-VSTA motherboard and an Asus Geforce GTX 260.
Info and stuff i've already tried:
Everything is connected correctly with the correct cables (EVERYTHING!!!!!).
The soundcard can definitely output HDMI SPDIF (http://www.asrock.com/MB/overview.asp?Model=ALiveNF6G-VSTA).
The graphics card came with a DVI to HDMI connector specifying which DVI slot to use for HDMI (i.e. including audio).
My resolution in nVidia control panel says HDMI > HDTV therefore the audio loss is definitely not due to faulty connections or a DVI signal through HDMI.
I'm running XP so i cant specify digital output only using windows.
Realteks audio manager has only the option to alter the output sampling rate of the SPDIF, it has no "enable spdif" or anything to say it is infact connected.
"Sound and audio devices" in control panel has only the Realtek HD listed as a device.
"Device control" in control panel only has altering the sampling rate as an option.
There are no audio option in nVidia control panel.
Under output in windows volume control the SPDIF control is greyed out and i can't move the slider.
I have the latest drivers and updates of absolutely everything.
I installed AC3 and enabled SPDIF there but that didn't help
I went into BIOS and there was no digital or spdif output options, only "onboard hd audio" which is enabled.
In nVidia control panel when i switch display devices from my monitor to the HDTV sound continues to be output through my pc speakers regardless, as if the graphics card is failing to switch audio channels.
A lot of info there, i tried everything i could find on the net but nothing works, HELP ME PLEASE!!!!! Cheers everyone.... or no one.
Sponsored Links
There are 1184 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
