Hi,
I just build myself a new system, and was mortified when I saw that the psu I bought only had one pcie power cable and my shiny new xfx 4870 1 gb needed two! I thought I'd give it a try anyway, and the system did boot. It was at this point I found the molex to pcie adaptors in my case, so I took an adaptor, plugged on two different molex cables. Now the graphics card wouldn't work - the fan seemed to be running but at much lower speed than before, and nothing on the screen. When I took out the extra power the card ran again. I tried all sorts of different combinations with the adaptors, but the card would only run if only one power source was plugged in. What should I think of all this? I read a review of a4870 card somewhere where they had the same problem but it performed well nonetheless.
as ubernoobie said the amps might not enough. the PSU may rated as 600w but if the amps are not strong enough it may face problems to power up the card
It says 28 amps... I guess that wont cut it after looking around on the net. My PSU is a LC6600 super silent. I guess I have to replace it. Will a corsair VX550W do the trick?
