Hi,
I just got a i7 2600k and I'm OC'ed @ 4.5GHz on a Asus p8z68-v PRO gen 3 Motherboard. I'm going to pick up a Cooler Master Hyper 212 today but I'm worried that my CPU temp might go up. I know it sounds ridiculous but with the stock cooler i'm getting 30c Idle and 60c Full load CPU temps after 3+ hours of gaming (individual CPU cores are about 10c more per core). I've read that some people are getting the same idle/full load temps with the 212 cooler OC'd at lower setting. Is there a possibility that I'll get higher CPU temps with the Cooler Master Hyper 212 cooler?
I've got decent ventilation using a Rosewill "gaming" case which has 3 fans in it (front, back, top). My MSI 560 TI Frozr II video card supposedly runs cooler than other video cards due to it's heat sinks and large fans. The PSU is bottom mounted and has two fans in it.
Additional notes: It is "winter" right now in California and I live near the beach.
Thank you.
Thank you.
