Cooler Master Hyper 212 Plus Vs Arctic Cooling Freezer 7 Pro Rev.2
Evening Peeps
Been looking at these 2 CPU heatsinks and wondering what would be the best to go for.
Not going to be overclocking, but my stock AMD cooler has a broken fin and it getting to around 40deg on idle.
What is the best one to go for.
One question with the Hyper 212 is how would i go about setting up the 2 fans as i expect 1 fan will be plugged into the CPU fan header on the Mobo. Where does the other one plug into? Does it have a molex on it or does it go onto another fan header.
Related ressources
Overclocking Authority
deejayburnout said:
CoolerMaster Hyper 212 EVO
£25.
Not bad.
Been looking at reviews and from what i gather, a push/pull only lowers it buy a few deg. Is it really worth it?
You might get another 1-2C temp drop with another fan.
Very difficult to match fan though.
The only place that sells the matched fan is the CM Store.
Got My 212 Evo last night and all i can say is wow.
Very easy to fit and missed my memory slots. Just fitted my Sharkoon T9 with a few mm to spare.
Idle temp is now 19 deg, and pc is a lot quieter.
Well happy with it.
Ask the community
