i just buit a new computer but i keep getting a bsod when i try to install xp (thats what the person i built for it wants) i tried win 7 rc and it worked they didnt like it. The xp is a old disk. i took the hard drive out and put it in my set up and it ran the installed fine, but when i put it back in the other build it said there was an error with the disk. the set up is
antec ill 300
HP 24X Multiformat DVD Writer Black SATA Model
GIGABYTE GA-MA785GM-US2H AM3/AM2+/AM2 AMD 785G HDMI Micro ATX AMD Motherboard
SAMSUNG Spinpoint F3 HD502HJ 500GB
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
AMD Phenom II X3 720 2.8GHz
consair 400watt power supply
antec ill 300
