I am building a mid range gaming pc,e.g. e7600 DUO CORE 3.06ghz CPU,,EP45-UD3L GIGABYTE MOTHERBOARD,XFX 4770 RADEON GRAPHICS CARD,NZXT APPOLLO CASE,GREAT WALL 550W PSU,4GB CORSAIR RAM,,??is the cpu and the power supply ok for my system,any advice is much appreciated,thanks in advance
The case is not a problem...But the PSU is...
I would suggest any quality 450W PSUs from Corsair/ Seasonic/ Silverstone/ PCP&S...
Rest are good...But for the price that you are spending, you could get better going with AMD X3 720...So with the money saved, you can get a faster GPU...
And if you can - http://www.tomshardware.com/forum/ [...] ild-advice
thanks for your reply gkay09,will my great wall 550w psu do the job reasonbly well,coz my budget is limited,and can i upgrade the xfx radeon 4770 card in the future with that system??
It would be able to handle the HD 4770...but I doubt it would be able to handel high powered graphic cards like the HD 4890/ 4870...
Could you post more details about that PSU ? And what other PSU options do you have ?
And do you already have that PSU ?
Feature:
◆ Comply with Intel ATX12V V2.2
◆ Dual rails +12V1,+12V2 output
◆ Fan 120mm for excellent thermal control
◆ Super silent with intelligent-thermal fan control technology
◆ 78%+ high efficiency performance
◆ Active PFC with PF up to 0.99
◆ Support Intel/AMD all series processor
◆ 20+4Pin connector for M/B
◆ SATA connector for HDD
◆ MTBF > 65,000 hours at 25℃
◆ EMI: EN55022 Class B
◆ Total output power 450W, Max output power 500W
Specification:
Voltage +3.3V +5V +12Vi/o +12Vcpu -12V +5VSB
Min Current(A) 0.5 0.3 1.0 1.0 0 0
Max Current(A) 22.0 20.0 14.0 16.0 0.3 3.0
Dimension: 150mm*140mm*86mm
Safety: CCC、CB、CE、UL
yes i do already have the power supply gkay09,all i could find on the great wall website was the 2.2 500w..but the one i have is a 550w...maybe it is new and not on the site yet,i got it from ....computeronline.com.au....,thanks for your time gkay09
