Northbridge NVIDIA GeForce 7050 rev. A2
Southbridge NVIDIA nForce 610i rev. A2
[B]Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16[/B]
Memory Type DDR2
Memory Size 3072 MBytes
Channels Single
Memory Frequency 266.7 MHz (3:4)
CAS# latency (CL) 4.0
RAS# to CAS# delay (tRCD) 4
RAS# Precharge (tRP) 4
Cycle Time (tRAS) 11
Bank Cycle Time (tRC) 16
Command Rate (CR) 2T
I just figured this out and I was wondering if I bought a PCI-Express 2.0 Card (BFG GeForce 9800 GT OC+ Video Card), would it work on my slot? I've heard that 2.0 is compatible with 1.0 but I need some help?
Sponsored Links
I have two PCIe 2.0 cards running in PCIe 1.0 slots, so I think you'll be fine.
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
Alright. Thanks for the quick reply. You were great help :)
Reply to venomx
You're welcome mate.
I am myself running a 9800GT on a PCIE 1.0 slot.Though there is some bandwidth limitations of 1.0 but there will be no significant loss(maybe less than 5%).
It will perform nearly the same as with 2.0 slot.
Reply to shubham1401
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Need some help
There are 1275 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
