Hey Forum,
I currently have a NZXT Tempest case but i feel like the stock coolers that come with it aren't very good. It feels like it's not sucking air out/in that well.
I don't know the specifications of the fans.
Top ones suck air from inside the case and blow it out upwards.
Rear one blows air outside the case.
Front ones suck air in.
** Does the side fan suck air in or blow air out?
So i was planning to buy some new ones to replace one Top fan above CPU (140mm), Rear Fan (120mm), Side fan (120mm).
120mm Fans
1.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=9_510&products_id=13960
Air Flow (CFM) :
Speed (RPM): 600-2000
Air pressure [ is this static pressure?] (mmH20): 0.75-3.53
Noise (dB-A): 13-30
Bearing Type: Barometric Ball Bearing
$29.00
2.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=9_510&products_id=8135
Air Flow (CFM) : 69.69
Speed (RPM): 2000
Air pressure (mmH20): 2.94
Noise (dB-A): 19
Bearing Type: Long Life Sleeve
$12.00
3.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=9_510&products_id=8022
Air Flow (CFM) : 90
Speed (RPM): 2000
Air pressure (mmH20): 3.04
Noise (dB-A): 19
$15.00
4.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=9_510&products_id=17324
Air Flow (CFM) : 80.3
Speed (RPM): 1800
Air pressure (mmH20): 1.96
Noise (dB-A): 30.5
$16.00
It appears that #3 is the best in terms of price/performance/noise? Does anyone have suggestions or vital information to add that i may be overlooking.
140mm Fans.
1.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=9_598&products_id=19135
Air Flow (CFM) : 86.73
Speed (RPM): 1200
Air pressure (mmH20): 1.38
Noise (dB-A): 22.8
$16.00
Also, if i left my case open and blasted the hardware directly with a normal air cooler (not aircon) (for house hold use, not CPU lol) would that also be effective?
Thanks.
120mm Fans
1.
Air Flow (CFM) :
Noise (dB-A): 13-30
$29.00
2.
Speed (RPM): 2000
Noise (dB-A): 19
$12.00
3.
Air Flow (CFM) : 90
Speed (RPM): 2000
Noise (dB-A): 19
$15.00
4.
Speed (RPM): 1800
Noise (dB-A): 30.5
$16.00
140mm Fans.
1.
Speed (RPM): 1200
Noise (dB-A): 22.8
$16.00
Thanks.
