Tom's Hardware > Forum > Graphic & Displays > Nvidia > No monitor signal on start up in SLI
hi, i recently upgraded my PC to SLI. I was having trouble with the setup at first, because my motherboard was not recognizing the 2nd card. I decided to go into the bios, and i change the SLI configuration, and everything worked well.
However, since then, whenever i start my PC i get no signal (cant see anything on monitor) until windows starts loading. Once that happens, everything works perfectly. I just cant see the BIOS.
I know this is a SLI problem, since when i remove my 2nd videocard, i can see the BIOS no problem on startup. This problem has persisted in vista and windows 7, although i doubt its a windows problem.
Any help would do please, as I cannot find much online. I feel asthough it isnt a product problem, but something silly in the BIOS, for example a setting.
thanks!
PC SPECS:
Monitor: proview
Videocard: geForce 9800gt SLI
Memory: 6 GB
motherboard: M2N-E sli
Power supply: 700 watts OCZ
Sponsored Links
Have you tried shutting down and then swapping the (I assume) DVI lead to the secondary card and then booting up?
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
- 0 +
yes i have. I tried the DVI into all 4 inputs, still no signal.
Reply to cam_96
I'm assuming you have the latest drivers, it's just that the last time this happened to me was back with a 7900GT SLi rig and it was a driver issue.
- 0 +
i do without a doubt for my video cards.
They only thing that might be in question is my motherboard. Ive gone to the nvidia site, and ive tried installing the latest driver. However i remain unconvinced that they have updates my motherboard.
How can i check this?
Reply to cam_96
Nv control panel > system information, will show what chipset drivers you have installed.
- 0 +
hi, thanks for all the replys.
i cant find my system information in the Nvidia control panel.
There arent any options called that
Reply to cam_96
Which OS are you on? W7, Vista or XP?
- 0 +
now, windows 7
Reply to cam_96
I'm not running W7 on my SLi rig so I am using the Vista install for reference :-
http://img33.imageshack.us/img33/3405/chipseto.jpg
Do you not get this after you have installed the nForce 15.51 drivers?
- 0 +
nope. I dont have both the performance and system update tab.
i could try and load vista and check, i think ive seen that before.
Reply to cam_96
There are 546 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 -pcaddict- won the Freshman badge
  • 01:00 impreza won the Freshman badge
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
