I'm building a new PC. Using an Intel DG45ID mobo running Vista 32bit and everything seemed to be working fine. My monitor is a Sony SDM-HS94B and it was plugged straight into the mobo via the DVI port.
Problem came as I tried to install a new GPU (PNY nVidia 9800GTX+). I put the GPU into the PCI slot and booted up the computer - no signal to my monitor no matter which DVI port I was using (either one on the GPU or the mobo). After rebooting my PC a few times with no signal, I finally opened up the PC, took out the GPU, and finally got a signal again on the mobo. The opening screen had a bunch of error messages the first time (too fast for me to read, but I caught the world "field" somewhere on the screen). So now I'm back to using the mobo's integrated graphics card.
I have a suspicion that I need to fix something in BIOS, but not sure what. Any suggestions?
Ya when the GPU is installed you mobo will automatically disable onboard video.
Did you plug in the 2x 6 pin power connectors? What are the specs on your PSU? I would suspect a power issue.
However, the fact that you got errors after you took the GPU out is concerning. If you continue seeing errors I would reset your BIOS and run a memtest.
I have a 450-500W PSU, so it shouldn't be an issue.
More background - this is actually the 2nd time I'm building this computer. The first time I built it, I ran the monitor on the mobo and then on a 6600GT (from my old computer) with no issues. I then swapped out the 6600GT for the new 9800GTX+ (that just came in the mail), and things were still fine - I was able to plug-n-play and only had to adjust some settings. Finally when I was doing some windows update (for Office, actually), the computer froze and I had to reboot the computer. I immediately started getting error messages during startup that wouldn't go away. I tried re-installing Vista and the error msgs still wouldn't go away.
So finally, I took out the new GPU, and re-installed Vista with the monitor attached to the mobo, this time the error messages finally went away, so I took great care as I installed all my updates, etc. Finally the real test came when I put the GPU back in again, but this time no signals whatsoever. I then took out the GPU again and plugged the monitor back into the mobo and I saw the error message the first time I rebooted my computer, but the error messages have since gone away.
I'll try to play around with my BIOS when I get home tonight, but I'm beginning to worry.
This is a problem with old drivers of nvidia.
Here is a resolution.
Download Drive cleaner, search for it in google, delete the old nvidia drivers with drive cleaner, install the new drivers, ready.
