URGENT QUESTION PLZ HELP
I have a hp simple save portable hard drive. iv been using i 1 year and suddenly one day it goes so slow and it lags my entire computer, it takes like 4 minutes just to go in a sub folder and the copy speed use to be 18-20mb now it goes at 2-6mb, i tried virus scan and error scan, i also tried it on another computer but its stil the same results
I
Anyone have any ideas on how to fix it,
8 answers Last reply
More about urgent question help
  1. Try a different computer. Sometimes drives go bad, in which case get as much data off before it dies. Not saying there's no solution...it might be something else...but you should prepare for that eventuality while it still works at all.
  2. Like i will try moving 1tb worth of stuff going at like 2mbs
  3. If you don't you may well be saying good bye to a TB of data.
  4. It'll take a while and if the hd is bad the giant transfer might kill it for good, but it is doable. Maybe prioritize based on how important the data is.
    It's not a pleasant reality, but it is definitely what you should do. If you don't have enough drive space then go buy a new external drive. If you can't do that then transfer as much as you can. If you still don't have enough drive space then rub some prayer beads and dive into some old forums while you wait for new responses on this one.
  5. Any other suggestions?
  6. maybe a trojan scan? sometime antiviruses dont catch them little buggers. also when drives tend to go bad, they emit kind of a rythmic clicking sound. anything like that is happening?
  7. You may try to get the disk out of the box and connect it internally in a desctop computer. In this case you'll at least know if it's a problem of the disk itself or is something with the enclosure controller.
    That is a useful technique for troubleshooting, but it will void your warranty and those things can be really hard to get out so be careful you don't damage the drive in the process. The apply-brute-force method should only be used as a last resort, but that may be where you're at right now.
Hard Drives Computer Hewlett Packard Portable Hard Drive Storage
