Tom's Hardware > Forum > Homebuilt Systems > New System Build > [Solved] Building my own computer, need help.
Forum Homebuilt Systems : New System Build - [Solved] Building my own computer, need help.
Best answer from englandr753.
Hey, I am thinking about building my own computer. I can go as high as $1200, but i would REALLY like it to be cheaper!
CPU: I am not really sure what to get here, so help would be needed here.
Mobo: I want a 790FX, with crossfire, so if you can find a good one, i would appreciate it.
Video Card: I am looking at the Radeon HD 5850 right now.
Case: I am looking at the Cooler Master HAF 932, but if its not good, i would like other tips. (Probably need a full tower because later i might want to get two 5850s
Power Supply: I want 700W-800W
RAM: about 4GB
Hard drive: 320GB-500GB
I also want a CPU fan. Anything will help, and don't worry, i'm getting help putting it together so i dont mess it up XD
Thanks all!
Lordofcattown
CPU 189.99 free shipping
http://www.newegg.com/Product/Prod [...] 6819103674
Motherboard 199.99 free shipping
http://www.newegg.com/Product/Prod [...] 6813131392
Video Card 379.99 + shipping
http://www.newegg.com/Product/Prod [...] 70&x=0&y=0
Memory 85.99 free shipping
http://www.newegg.com/Product/Prod [...] 6820145260
Case 139.99 free shipping ends tomorrow!!! ;)
http://www.newegg.com/Product/Prod [...] 6811119160
Power Supply 99.99 free shipping
http://www.newegg.com/Product/Prod [...] 6817139006
Hard Drive 74.99 free shipping
http://www.newegg.com/Product/Prod [...] 6822148445
DVD Drive 28.99 + shipping
http://www.newegg.com/Product/Prod [...] 6827136167
CPU Cooler 33.98 free shipping
http://www.newegg.com/Product/Prod [...] 6835186134
1233.90 + apprx 20.00 shipping
I overshot you on the video card, this can be dropped down to the 5850 you were looking at and this will give you the additional money needed to get the operating system if you don't have one.
This is one of many good suggestions... ;)
Sponsored Links
Also, if i am missing anything, please tell me. Thanks!
Reply to lordofcattown
CPU: http://www.newegg.com/Product/Prod [...] 6819115202
MB: Not a big mobo guy but heard this was good http://www.newegg.com/Product/Prod [...] 6813188039
GPU: Yep, 5850 is where it's at right now
Case: HAF is amazing, get that or the antec 1200
Power: You want a 1000w if you plan on doing a 5850 crossfire
Ram: http://www.newegg.com/Product/Prod [...] 6820231193
HDD: http://www.newegg.com/Product/Prod [...] 6822152181
------------------------------ War is fear cloaked in courage
Reply to Sythix
i guess if its gonna cost a lot more, i wont get the 5850 crossfire, ill stick with the mobo, but maybe get another power supply, but what should i get?
Best answer
------------------------------ EVGA 780i mobo | EVGA GTX 275 | Q9550 OC @ 3.6Ghz | 8Ghz 1066Mhz Corsair Memory | Corsair 1000 watt PSU | Coolermaster Stacker CM830 Case | Ultra TEC CPU Cooler | Vista Ultimate 64
Reply to englandr753
for the CPU, if i went a cheaper route, which one would be better? the Core 2 Duo E8500 or the Phenom II X3 720 BE?
AMD, the 775 socket is dead and will have limited upgrade options...
If you are looking at a PhIIx4 you should also consider an i5. If you want to go cheaper go with the PhIIx3 720. Dont get a socket 775 CPU.
Englandrs build even had the GPU upgraded to a 5870. You would save $100 dropping it to a 5850.
I would go with a Samsung F3 500GB or 1TB since its 500GB platters with be faster than the Seagate 750 he has listed.
Also that crosshair is an expensive motherboard. This gigabyte is $75 cheaper and will do everything you want.
http://www.newegg.com/Product/Prod [...] 6813128378
You could also save money by going with a the HAF 922 or an antec 900. 5850s are a fairly short card (only 9 inches, many performance cards are 10-11 inches) so you could probably even go with an antec 300 illusion.
You only need a good 650W PSU to crossfire two 5850s; a 750W gives you room to overclock and add lots more SSDs, HDDs, etc. 1000W is for 3 or 4 card crossfire systems.
Message edited by dndhatcher on 10-07-2009 at 02:33:28 AM
Reply to dndhatcher
Make sure your motherboard you chose supports the quad cores. You may find yourself wanting to upgrade later.
Is your plan to try and unlock the 4th core on that cpu? I would get the ram I suggested and put the money into getting a quad core cpu and don't depend on getting lucky to unlock that cpu. It doesn't always work out to a happy ending.
Everything looks good to me. Happy building... ;)
Message edited by englandr753 on 10-07-2009 at 06:59:50 AM
Just wondering... what monitor are you using?
Reply to dragoon190
Im using a 21.6" SOYO monitor, its actually really good! And yeah, i checked out the mobo, and it does support a quad core, so i think i am going to get the computer around christmas, and i might upgrade later. Thanks everyone!
Large mid-towers like the HAF 922 and Antec 900 or 902 are only an inch or so shorter than the full towers and would easily handle two GPUs for less money.
Reply to dndhatcher
the HAF 932 has 1 140mm fan, and 3 230mm fans, while the 922 has 1 120mm fan, and 2 200mm fans. so the 932 cools a lot better. If i do get the 932, should i still get a CPU cooler?
You should get a good CPU cooler regardless of anything else. You need the heatsink and all those fins for the air to do its job.
Reply to dndhatcher
What did you decide? :bounce:
Message edited by englandr753 on 10-08-2009 at 08:37:29 AM
There are 667 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
