Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Question... will a PC power up without a harddrive installed?
Forum Homebuilt Systems : General Homebuilt - Question... will a PC power up without a harddrive installed?
Hi. I sold an old PC on ebay a few days ago. I did not include a hard drive with it. The guy who bought it says it won't power ON without the hard drive installed. He wanted to check to see if the fans would light up and start before he unpacked the new hard drive he bought for it. I guess he can't return it if it is open.
So my question is should the power supply power up and the case fans light up and run if the PC does not have a hard drive installed?
Thanks!
-Freak
Message edited by jrfreak on 10-07-2009 at 01:07:07 AM
Sponsored Links
Yes,,but only as far as the bios..After all no OS no boot,,EH ??.:)
------------------------------ When you obsess on your enemy,,
You become The Enemy...
Reply to dokk2
As long as there is nothing wrong with the core components, ram, psu, cpu, cpu heatsink n fan, motherboard. The comp should power on, with the fans spinning up, add a graphics card or use onboard video, and he should see the bios post screen, add a keyboard, and the bios post will complete. Now it should show a black screen with an error saying that no hard drive is installed.
So, in short, yes as long as everything else is in working order and connected properly, his comp (the one you sold him), should startup with the fans spinning up.
Reply to Boxa786
There are 1167 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
