GA-MA785GM-US2H Power Requirements
Hello,
I'm looking to build a new setup for my sister with an Athlon X2 630 quad core and a GA-MA785GM-US2H MB. I plan on running 2 1TB drives in raid 1 and possible 1-2 DVD drives, 2 sticks of DDR2 memory and 1 120mm fan on a 450W BFG power supply. I've read in the documentation that 500W is recommended but calculating this using eXtreme Power Supply Calculator Lite I'm getting around 220W. Will I be ok with this MB and the components that I've listed?
Also we have a old Maxtop ATX case I can reuse for the new setup. The only problem is that the front panel was and I believe is a USB 1 interface. Can I hook up the front panel to the USB 2.0 ports on the MB or will that ruin the MB?
Thanks,
Nick
npolite said:
Hello,
Thanks,
Nick
Heres a link to a PSU Calculator:
http://educations.newegg.com/tool/psucalc/index.html?Tp...
Your current hardware above requires a:
You need at least a 388W
What you have up top will be fine! Trust me.
You will be okay as long as your NOT trying to run a high end graphics card.
bilbat said:
Plenty of oomph, especially if you're never expecting to toss in a hefty graphics card...
Thanks for the info...no plan on doing more than web/photo editing on the intergrated video.
Related ressources
Motherboard Authority
Quote:
I was just asking before pulling the trigger on the purchase
Always a noble idea! [:bilbat:5] If more people 'did their homework' before 'pulling the trigger' on their credit card - there'd be fewer problems posted here; and, once they have your money, it's infinitely harder to 'pry it loose!'
My policy is: download and read every manual for every considered purchase - and if the manufacturer can't be 'bothered' to post a decent manual, I can't be 'bothered' to send 'em money!
npolite said:
Yeah everything hopefully will be good...I was just asking before pulling the trigger on the purchase
Tell us how it goes and if you have anymore questions just post them on here.
Ask the community
