Tom's Hardware > Forum > Homebuilt Systems > New System Build > Budget AMD build, parts check
Forum Homebuilt Systems : New System Build - Budget AMD build, parts check
APPROXIMATE PURCHASE DATE: this week
BUDGET RANGE: ~$600, would like to keep it <$700
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Internet surfing, programming, multimedia, virtual machines
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS, (possibly optical, see below)
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, open to other suggestions
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: AMD CPU, AM3 mobo, DDR3 RAM
OVERCLOCKING: Yes
SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1600x1200
ADDITIONAL COMMENTS: Haven't done a build in about 6 or 7 years, so my knowledge of current technologies is woefully outdated. I'm hoping to be running 64bit Ubuntu. Will be doing a lot of programming/experimenting/testing. Planning to run Windows XP and some Xen instances running some other forms of Linux (thus 8GB RAM). Any gaming will be on the very light side, and probably in the XP VM.
I've selected the Athlon II X4 620, which I hope to OC to around 3GHz. Hopefully, the mobo selected will make it easy to do this. If not, I'm open to suggestions as I'm very much clueless on OC'ing. I'm also thinking/wondering about the Phenom II X3 720, and wonder if I could benefit from it's L3 cache, based on intended usage? Please feel free to make any substitutions or suggestions which might make my life easier.
As mentioned above, I have an optical drive that's fairly new, but it's ATA, not SATA. Also have an 300GB ATA drive that I'd like to throw in there for some backup space. Would performance suffer greatly having to mix ATA with SATA?
The parts (from newegg.com):
(2) G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory
Item #:N82E16820231275 -$5.00 Instant
$169.98
$159.98
(1) OCZ ModXStream Pro OCZ500MXSP 500W Power Supply compatible with core i7
Item #:N82E16817341016
-$25.00 Instant
$20.00 Mail-in Rebate Card
$89.99
$64.99
(1) LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04
Item #:N82E16827106289
$27.99
(1) COOLER MASTER Centurion 5 CAC-T05-UB Black /Blue Computer Case
Item #:N82E16811119047
$54.98(1) GIGABYTE GA-MA790GPT-UD3H ATX AMD Motherboard
Item #:N82E16813128398
-$10.00 Instant
$15.00 Mail-in Rebate Card
$124.99
$114.99
(1) AMD Athlon II X4 620 2.6GHz Socket AM3 95W Quad-Core Processor
Item #:N82E16819103706
$99.00
(1) SAMSUNG Spinpoint F3 500GB 3.5" SATA 3.0Gb/s Internal Hard Drive
Item #:N82E16822152181
$54.99
Grand Total: $621.92
Total with Discounts: $576.92
Total with Discounts and Rebates: $541.92
Sponsored Links
I don't think that the cpu you've chosen is a good overclocker because it isn't BE, I would recommend getting a PII X3 BE http://www.newegg.com/Product/Prod [...] 6819103649 at 119$ or getting a PII X2 BE http://www.newegg.com/Product/Prod [...] 6819103680 at 102$. moreover if you fancy a quad and have some balls you might try to unlock the disabled cores in each one.
Reply to Daggs
For the extra $20 I'm not opposed to a PII X3 720 BE. Are my choices of MB and RAM good for OC'ing this chip?
Reply to bitznbytz
mb seems ok, don't know about the mem, I don't know much about mem oc
Reply to Daggs
Your motherboard is a good overclocker. I would spend a few more dollars and pick up the CAS 7 version of the Ripjaws.
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-4GBRH - Retail $88.99
Reply to shortstuff_mt
Looks like newegg is all out of the 500GB Spinpoint HDDs. I'm opting for a 1TB Spinpoint, as follows:
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
Item #: N82E16822152185
To keep costs down a little, I'm going to drop the Lite-On DVD burner. I will re-use the aforementioned existing PATA based burner. With support for two PATA devices on this mobo, I think I can get away with this burner plus my backup drive. Any other thoughts or caveats? I'll post an updated parts list shortly.
Reply to bitznbytz
Updated build specs. Dropped the SATA burner, upgraded to 1TB Spinpoint HDD, swapped for AMD PII X3 720 CPU and CAS7 RAM. Added a couple of 18" SATA cables. This is about +$40 over my initial design, but still within budget. Taxes and shipping are killer. Wish there was some way around the latter, if not the former ;-)
(1) AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core Black Processor
Item #:N82E16819103649
-$5.99 Instant
$124.99
$119.00
(1) OKGEAR 18" SATA II Cable
Item #:N82E16812123175
$1.99
(1) OKGEAR 18" SATA II cable with metal latch,UV BLUE
Item #:N82E16812123111
$1.99
-$25.00 Instant
$89.99
$64.99
Item #:N82E16820231276
$177.98
Item #:N82E16813128398 -$10.00 Instant
$124.99
$114.99
$54.98
(1) SAMSUNG Spinpoint F3 1TB 3.5" SATA 3.0Gb/s Internal Hard Drive
Item #:N82E16822152185
$79.99
Total: $615.91
Total with Rebates: $580.91
Tax: $50.81
Shipping: $33.68
Grand Total: $700.40
After Mail-in Rebates: $665.40
Reply to bitznbytz
You don't need the SATA cables. Your motherboard comes with two SATA cables.
There are 863 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
