So I am, like many, looking to upgrade to i7. I do a good deal of high end gaming and work with Premiere Pro and After Effects. Going to do the build myself as always.
Current usable parts:
Seagate Barracuda 1.5 SATA
WD 300 GB SATA
Seagate 300 GB SATA
Nvidia Geforce GTX 260
OCZ GameStream 700w PSU
Antec p160 case (old, likely need upgrade though I am rather fond of it)
Near new quality intake and exhaust fans(120mm)
Going to run Windows 7 64 bit
Looking to get:
i7 920 - for sure (going to OC to around 4.0)
MOBO - Been looking at the ASUS P6T6 Revolution (bit pricey)
RAM - Not sure here what is best bang for buck
Cooling - Prolimatech Megahalems with one or two fans (prefer this over WC)
I went with the GTX 260 for cheap and easy SLI upgrades. considering its onsale right now I could 3 way it without much trouble and more video than I will need for a good long while. (2 way with my current PSU.)
Any help would be great, my budget is ok as long as I am getting the best bang for my buck and longevity in my parts.
Thanks much,
Mace
WD 300 GB SATA
Seagate 300 GB SATA
Looking to get:
Thanks much,
Mace
