Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Computer Noise reqs help
Forum Homebuilt Systems : General Homebuilt - Computer Noise reqs help
i built my computer last yr with these specs
-Asus p5n-d
-sony 20x dvd burner eide
-intel core 2 quad Q6600
-corsair twinx 2 gig(1gig x2)
-mass cool 8wa741 cpu fan w/ heatsink
-seagate 320 GB serial ATA HD
-Raidmax Performance Katana
-XFX geforce 8800 GT graphic card
ever since i built it, its hasnt been bothering me as much, since i usually ignore it. but lately i moved my room around and had to move my computer onto my table. my computer is Very Loud. i have 3 fans on the case one front and the other is the back, both are 120mm fans, the side contains a 80mm fan. however i dont think the sound is coming from the fans, becuase i unpluged all 3 of them, and my computer still made that noise. so that just leaves my cpu cooler fan, and the graphic card fan. i dont know which is making the noise.
Sponsored Links
And the power supply fan.
You'll need to figure out which fan is the offending part for us.
Reply to WR2
I'd start out unplugging 2 of the case fans. The side 80mm and front 120mm. You can safely run your system at idle without those 2. And then you can continue to try and figure out where the problem is.
I'd checkout the PSU fan first.
Message edited by WR2 on 10-08-2009 at 03:10:20 AM
Reply to WR2
i checked both the 120mm and the 80mm fans, and those fans arent making noise.
how would i check the psu fan?
Reply to zelkon
Put your ear next to the PSU with the rear case fan unplugged.
Reply to WR2
no, i dont thnk its coming from the psu, i believe is either coming from the graphics card, or cpu cooler
Reply to zelkon
i also checked the cpu fan, and i dont think its that. the leaves the graphic card last. i tried to lower the fan speed using the nvidia control panel software, however it doesnt seem to have done anything.
Reply to zelkon
There are 1042 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
