Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help Build Gaming Machine
Forum Homebuilt Systems : New System Build - Help Build Gaming Machine
APPROXIMATE PURCHASE DATE: Oct 22nd
BUDGET RANGE: $1000-1500
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Internet, Gaming, Photoshop
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: 1920x1200
Based on research of I've selected the following components:
CPU: Intel i5 750
MB: Asus P7P55D
RAM: Kingston ValueRAM - Memory - 4 GB ( 2 x 2 GB ) - DIMM 240-pin - DDR3 - 1333 MHz
VC: Leaning towards Radeon 5850
HD: WD 1TB WD1001FALS 3.5" SATA 32MB BLACK 7200RPB
PSU: Antex TRUE POWER TRIO TP3-650 650W ATX V2.2 APFC 12CM 4" SATA
CD: Samsung SH-S223F 22x DVD RW Drive
Any feedback or advice would be helpful. Thanks.
Sponsored Links
Where do you live and where do you prefer to acquire parts? Eg. newegg.com, microcenter, etc.
Reply to mavanhel
I live in Toronto, Canada. I have no preference.
Reply to dsulkers
CPU: Intel i5 750 $220.99
Motherboard: GIGABYTE GA-P55-UD4P $189.99 (better than the ASUS one you chose for SLI/XFire because it will operate at x8/x8, instead of x4)
RAM: G.SKILLS Ripjaws Series $95.49
Video Card: Radeon 5850 $279.99 (but by Oct. 22nd the XFX one might be out in Canada. I would suggest that one.)
PSU: Corsair 550VX $98.99 (before $20 MIR) for single GPU or
Corsair 750TX $149.99 (before $20 MIR) for Xfire/SLI
HDD: Seagate Barracuda 7200.12 1TB $129.99 + Free shipping
Optical Drive: Sony Optiarc Black $32.99
Case: CoolerMaster HAF 932 $149.99
Total: $1198.42 or $1249.42
I would suggest the Samsung F3 Spinpoint, but for some reason Newegg.ca doesn't carry it any more. If you can find it around where you live that would be great since it is faster and more reliable than other drives.
Reply to mavanhel
Thanks a lot. Would there be a problem if went with this case instead?
http://www.infonec.com/site/main.p [...] &id=353163
Reply to dsulkers
For the 5850 I think you should be fine. The only worry is that the GPU fits inside the case but a 10.5" card fits inside the Antec 300, so unless I don't know how to count, I'm sure the 9.5" 5850 will fit inside the case. The only thing with cases is making sure your parts will fit, airflow, and whether or not you like how it looks. Personally I like a full tower because I prefer a lot of room to play around, but like I said, it's all personal choice. But after that little rant, I'd say that the 300 is a pretty good case, especially for the price.
To clear up that confusing mess up there, no, there is no problem with that case.
Reply to mavanhel
Thanks for your help Mavanhel.
Reply to dsulkers
Anytime. It gives me something to do at work 'cause the government doesn't give me anything to do. (FYI, I'm in Canada too, these are your tax dollars hard at work :P)
Reply to mavanhel
Since I'm paying for this, are there any suitable motherboard alternatives from this supplier? I noticed they don't carry the UD4P...
http://www.infonec.com/site/main.p [...] catID=1699
Reply to dsulkers
The GIGABYTE GA-P55M-UD4 might suffice, even though it's micro ATX. The difference here is that there are less expansion ports and SATA ports. If you'd like to keep the full ATX experience you could go with the GIGABYTE GA-P55-UD5 but this one is a bit more expensive (but still within your budget).
You could also go with the ASUS P755D PRO, which is a lot like the GIGABYTE UD4P.
Note: I know it looks like I told you not to use this one, but when you mentioned the P7P55D in your first post I assumed you meant the LE, but the PRO will work just fine for your needs.
Reply to mavanhel
You should consider the samsung F3 HDD instead of that seagate.
http://www.infonec.com/site/main.p [...] &id=351623
Reply to dndhatcher
Good call. I took it out because newegg.ca isn't supplying it anymore for some reason.
Reply to mavanhel
Thanks, what's the advantage of the Samsung or Seagate compared to this one?
http://www.infonec.com/site/main.p [...] &id=410502
Reply to dsulkers
Well, the Samsung is a little bit cheaper and actually runs faster. It uses 2 500GB platters instead what WD uses (something with greater than 2 platters). The two platter system offers a lot faster read/write speeds overall.
Reply to mavanhel
Thanks for your help man. I really appreciate it.
Reply to dsulkers
Im pretty sure the WD 1Tb is a 4x250GB platter drive.
Reply to dndhatcher
OVERCLOCKING: Maybe
CPU: Intel i5 750
MB: Asus P7P55D
Wait until the msi big bang comes out in a month.
------------------------------ When searching for Bearded Clams whatch out for those Crabs
Reply to smokinu
There are 1305 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
