I just built my fist system so am pretty new at this, wondering if anyone can shed some light for me on a mobo/ram issue
I installed 12Gb Corsair TR3X6G1600C8D RAM and it seemed to be working fine and was listed in the BIOS as running at 1066MHz. I heard about XMP and thought, hey why not try it to see if I can actually get it run the "advertised" 1600MHz with a simple option. So, I enabled XMP and got through one boot but on the second one I got an error from the bios.. something like:
"The system has experienced boot failures because of overclocking or changes of voltages ...."
I ran memtest (at 1066MHz) and found no errors. Corsair has recommended I memtest each module separately with XMP enabled, one a time to see if one stick in particular might have a problem that didn't show up with XMP off.
To me it sounds though that the XMP changed some bios settings that my board didn't like and it's not really faulty memory. Is this possible or can someone provide another explanation?
Sorry for all the words and thanks for your help.
