Greetings,
This isn't the typical overclocking memory question given my situation.
Here's the System Spec's:
Intel DX58OG / BIOS Version 0876
Intel Core i7-960 @ 3.8gHz (200x19) / Corsair Hydro H60
Kingston HyperX KHX1600C9D3T1BK6/24GX, 24GB (6x4GB) / 8-8-8-22 / @1201mHz
KINGWIN ABT-610MM 610W
PowerColor Radeon HD 6870 1GB
Western Digital WD6000HLHX 6Gb/s 10000RPM
Windows 7 Home Premium SP1
I am overclocking my system, as the system spec's indicate.
The Problem: I would like to have the memory run at 1600mHz as per the advertised memory kit suggests, however I cannot get my system to pass POST when i try to bring the memory frequency above the value listed above, at 1200mHz. I can certainly live with the frequency and timing, but I would prefer to be running at the advertised 1600 / 9-9-9-27 as the kit advertises.
Note that I have a total of 6 sticks installed, the max amount for this board.
I have had success getting the system to boot & stable with stress tests with the above memory configuration (1200mHz / 8-8-8-22 ) with the following voltages: V-DRAM = 1.525V , V-UNCORE = 1.400V
Whenever I bring the voltage to the DRAM over a certain level or farther than about 0.05V from the UNCORE/QPI voltage, the system won't pass POST. This condition is true up to 1.625V/1.575V, but then when I bring it up any higher it's a complete wash, no pass POST regardless of my settings.
Can anyone offer some suggestions of what I might try to get this set of RAM up to higher speeds?
Thanks!
Thanks!
