Tom's Guide
Tom's Hardware
Laptop Mag
TopTenReviews
AnandTech
SS-logo-horizontal
Articles & News
Forum
Graphics & Displays
CPU
Components
Motherboards
Games
Storage
Overclocking
Tutorials
All categories
GPU HIERARCHY
CPU HIERARCHY
Brands
Tutorials
Other sites
Tom's Guide
Tom's IT Pro
Login | Sign Up
The authority on tech
Search
Builds
Cases
Cooling
CPUs
Graphics
Laptops
Memory
Monitors
Motherboards
more
Peripherals
PSUs
Storage
VR
Forum
Storage
Can i use a SATA 3Gb cable to connect a 3.0gb hdd to 6.0gb motherboard port
Noobie_
Aug 17, 2011, 6:10 AM
connecting 3.0gb cable and hdd to a 6.0gb motherboard port? will there be any problems doing this?
answers
Last reply
Aug 17, 2011
More about
sata cable connect motherboard port
Twoboxer
Aug 17, 2011, 7:44 AM
No
foscooter
Aug 17, 2011, 4:01 PM
Yes
you can. SATA 3 is backwards compatible.
No issues as long as you have the correct SATA drivers.
But, be aware that there will be NO increase in speed between a HDD on either SATA II 3.0Gbps or SATA III 6.0 Gbps ports.
No HDD even comes close to the bandwidth limit(s) of SATA II, much less III.
Get the answer
Hard Drives
Motherboards
SATA
Connection
Cable
Storage
Related Resources
Can I connect my WD HDD to SATA 3 port?
Can a SATA I cable work with sata III
Is using a 6.0gbs sata cable on a 3.0gbs HDD good/bad?
SATA III on the GA-X58A-UD3R
Can I run a SATA 1.5 Gb/s HDD through a SATA 3.0 Gb/s port?
Sata Cable :(
Broken sata port, Damaged motherboard?
My sata cable clamp broke :( HELP ..
How to attach sata hdd if sata port is finsih in motherboard
Where to get an SATA cable?
Male-to-male or female-to-female SATA 3 cable to connect an SSD?
SATA III HDD on SATA II Motherboard
SATA II in Cable in SATA 3 Port
Sata cable confusion
SATA cable ripped port off HDD
SATA to IDE Cable?
Sata Cable
Were to plug sata cable of harddisk on motherboard in esata or sata port
ESATA to SATA Cable - HDD not detected
Multiple HDD´s
More resources
