Archived from groups: alt.cellular.cingular (More info?)
In article <QJ3Wd.1414$CW2.1398@newsread3.news.atl.earthlink.net>,
Leanin' Cedar <Nospam@nospam.org> wrote:
>I have a "refurbished" phone, and either the battery is old or the memory
>has been shot.
>I did some Google and was overwhelmed by the places to buy batteries, and
>not sure which are OK.
>I just want to replace with the NiCad battery that was in it. The phone is
>only used for emergencies so no need to upgrade the battery.
>I would appreciate a couple of recommendations.
You can usually get tons of OEM and third-party batteries on eBay. It is
recommended to get genuine Nokia batteries due to reported safety issues
with Nokia knock-offs; also the OEM batteries tend to last longer as they
are made with higher quality cells.
The problem with older phones is that sooner or later battery production
is going to stop. Even before that, unsold batteries will sit warehoused
for longer and longer periods because there is less demand for accessories
for discontinued models. In either case, even a "new" battery you buy is
likely to have been sitting around for a while.
Why is this important? The chemicals used to manufacture lithium-ion
batteries (that is the chemistry used in the 8260 batteries) have a maximum
useful life of about 3 years from the date of manufacturer ... whether
they are actually used during this period, or not. So be prepared for a
"new" battery may not deliver the stated talk and standby times because it
isn't really new.
Thanks for the info.
Bob
"Mike S." <retsuhcs@xinap.moc> wrote in message
news0ais8$pvn$1@reader2.panix.com...
> maximum
> isn't really new.
On Fri, 04 Mar 2005 20:41:20 GMT, "Leanin' Cedar" <Nospam@nospam.org>
Cell phones have not used NiCad batteries for *years!* Your phone may
have a Nickel Metal Hydride battery or Lithium Ion, but it's highly
doubtful that you're going to find NiCad batteries in a modern phone.
NiMh batteries will lose charge even with no use over a period and
moreso than will Lithium Ion batteries. Don't expect a phone to work
that's been sitting in your glove box for months with extremes of
temperatures as well.
I own an 8260 and it came with a Nickel Metal Hydride battery standard.
Fred
"Joseph" <JoeOfSeattle@yahoo.com> wrote in message
news:1oek211k957baeb3njnjcvhf4qckbrm6fu@4ax.com...
is
