Hello,
I installed Dynamic Energy Saver 2 (DES2) without any prior changes to the BIOS (I had not set CPU Enhanced Halt-C1E and CPU EIST Function to Enabled). When I ran it, it suggested to install Dynamic Energy Saver Advanced. I also installed that one too. When I ran it, I pressed the "Advanced ON/OFF" switch (on the GUI) to activate it. Immediately the system shut down, it went into a sleep mode and it seems impossible to restore it. When I press the start button the fans turn for an instant, the LEDs flash and then the system is halted. Only two LEDS remain ON, No. 1 (yellow-orange) and No. 2 (green), on the right hand side of the last RAM slot (4th LED and 5th LED from the top, below a set of 3 capacitors). I tried to reset the CMOS many times, I also took off the battery for many hours and nothing seems to work. Can you give me instructions how to recover the system from this state back to normal?
Thanks in advance
GA-EX58-Extreme, BIOS: F3 (or later), Nvidia Quadro FX1500, i7 920 2.67GHz, Windows 7 Ultimate 64-bit, 3x2GB DDR3 Kingston 1333MHz, PSU: ThermalTake 1000 W
Case: ThermalTake Armor+ LCS, Hybrid Silent Pipe installed
System SSD Intel X25-M, no overclocking
Thanks in advance
