Tom's Hardware > Forum > Homebuilt Systems > New System Build > New builder need help
Forum Homebuilt Systems : New System Build - New builder need help
I am a new builder and I'm going to build a PC for my uncle and I know how to build it but I'm not sure about the software. What do I install after I'm done with the build and how do I do it?
Sponsored Links
Well, there is Windows 7:
http://www.microsoft.com/windows/w [...] fault.aspx
Or, Ubuntu Linux:
http://www.ubuntu.com/
Those two I recommend as of now. Are you asking about Operating Systems or software? Because that question is way to general to simply answer.
------------------------------ How To Ask for Build Advice
Intel I7 860 @ 2.8Ghz - CM Hyper 212+ - Asus P7P55D Pro - HIS Radeon HD 5850 - WD Caviar 160&320 GB - Samsung SH-S223B - CM 690 MidTower - CM 700 SilentPro
Reply to era86
OK for your uncle means windows.
I would install windows, openoffice, firefox, flash, java, and acrobat reader.
Reply to suddenstop
1) Install Windows OS by turning on your PC, hit the "del" key to enter into your BIOS. Search your BIOS for boot sequence and have it set to boot from DVD first. Save your BIOS
2) Install your OS disk into the DVD, boot your PC and follow through the on screen prompts untill it is completed installed.
3) Install your board, sound & video card drivers.
4) Install Apps and Games as you require.
Once built, I recommend running Prime95 to ensure your system is stable from heat or any other possible errors. Memtest86 is another good program to test the stability of your RAM.
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
Tecmo - are those free tools? I'd like to do that with my newly built system after I install 7 tonight. Will they run on 7 just fine?
Reply to era86
Yes... These programs are free to download!
Reply to tecmo34
There are 1205 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
