Closed
CPU heat issue - thermal paste or better heat sink?
January 18, 2012 5:33:53 PM
Hi Everyone!
I recently purchased a motherboard/cpu/memory upgrade for my rig. After hooking up my i7-2600k, I noticed some heat issues with my cpu.
Here's my info on the rig:
-corsair graphite 600t special edition white mid tower case
-intel i7-2600k processor & stock heatsink and thermal paste
-cpu is still at stock speeds
-asus P8Z68 deluxe/gen 3 motherboard.
-CPU temp sensor at idle - 26C
-at full load - 72C
- Mobo temp at load and idle - 30C
My cpu jumps to 72C within 10 seconds on a full load. If I overclocked it to about 4.4-4.6GHz, would a better thermal paste solve the issue or would a new heatsink be needed as well? I want to keep the rig air cooled. If a new heatsink would be needed, which one would you guys suggest for it?
Thanks in advance!
Best solution
a c 120 à CPUs
a c 117 V Motherboard
a c 183 K Overclocking
January 18, 2012 7:20:17 PM
Go for a heatsink.
The CM 212+ or Evo are very good low cost units. = both come supplied with a tube of very good paste.
a b à CPUs
a b V Motherboard
a c 125 K Overclocking
January 18, 2012 7:20:52 PM
Good thermal paste like AC5 or MX-4 will reduce the load temps by a few degree's but a good heatsink will make alot more difference.
What RAM are you using? I ask because some larger heatsinks may not fit over the top of your RAM if your RAM is tall.
Also what is your budget?
Score
January 18, 2012 7:57:18 PM
I'm using G Skill sniper low voltage RAM. I'm using 4 sticks. The motherboard is an ASUS P8Z68 Deluxe/Gen3 board.
I'm aiming for air cooled and do not want to spend more than $50
Thanks!
Score
January 19, 2012 2:42:31 AM
Best answer selected by confusedtechguy.
Score
January 19, 2012 2:42:34 AM
I've decided to go with the CM 212 with arctic silver 5 paste. Thanks for the help!
Score
a b à CPUs
a b V Motherboard
a b K Overclocking
January 21, 2012 12:46:43 PM
This topic has been closed by Mousemonkey
Score
