DVD/CD write problem?
Hi
I made a video, which is working good on pc and internet but when I writes it on dvd/cd then video is not running properly, I used different players and sometimes video runs improperly, and sometimes I can hear all sound but video stops at a point , sometimes video runs rapidly on some scenes, I wrote it on dvd with 2x and I wrote it on cd with 4x speed and cd is showing more problem then dvd
I can't give this cd in company as it looks like jerk in characters when cd runs it rapidly or stops at a point
My dvd writer is running other cds and dvds properly
so I wonder what to do? what's problem ?
my movie is quick time movie I think format shouldn't be issue, may be I should try on 1x speed(my dvd rw is 52x Lg)
video size is 130 mb
Please help me to get rid of this problem so I can forward my cds
thanks
5 answers Last reply
More about write problem
  1. What matters is the bitrate you encoded it in. If the bitrate is too high then you would experience jerkiness.
    Hi
    when some writer (new) shows problem in writing/reading specific cds/dvds not all so its writer problem or cd/dvd quality problem?
  3. Let me put it another way. If your 130MB QuickTime file is only a few minutes long then the bitrate is too high for a CD or DVD disk.
    Now, using a CD or DVD recordable disc will likely give you a higher transfer rate than a rewiteable dosc, and recording at a very slow speed, even 1x, might help.
    Hi
    yes its 2 min video
  5. What codec are you using? Perhaps you can reduce the bitrate by using a better codec and still have the same quality.
DVD Writers DVD Video CD-Rom Storage
