Tom's Hardware > Forum > Graphic & Displays > Nvidia > Lower power Nvidia card
Hi
I'm intending to buy a Shuttle SN78SH7 Barebone System - which I'm going to fit out with an Phenom II x4 945 (95W), 4 GB of 800Mhz ram, 1x7200 sata drive.
The shuttle system has integrated graphics, but I'd like to fit a low->mid range card in it. The problem is the power supply is 300W.
Could someone suggest a decent Nvidia card that would work with the 300W power limitation?
I've decided against ATI, basically because I need support in linux - and it seems that the ATI driver support is quite a bit worse than Nvidia.
thx in advance
Sponsored Links
Hello and welcome to the forums :)
Here is the support list:
http://au.shuttle.com/support_list03.jsp?PI=939
The best model of those is 8800GT
Reply to Maziar
- 0 +
@Maziar;
Thanks for the quick response... in that case it looks like the 8800GT will be the best option. The ASUS Geforce EN8800GT seems like a good bet, maybe?
Reply to lukus
- 0 +
Hi again...
I've just been looking at prices and availability - do you know off hand whether the ASUS GeForce GT 220 would be compatible? It's not on the list, but afaik it's a new (budget) card... so I suppose that's to be expected.
Reply to lukus
- 0 +
Yes the 8800GT is still a good card,about GT 220 you better ask shuttle.
BTW do you want to play games ?
Reply to Maziar
- 0 +
I'm not super concerned about games - my bigger concern is being able to run open gl decently - but I think most cards should be able to handle this. I do a bit of 3d modelling / animation as a hobby.
What's your opinion of the GT 220?
Reply to lukus
- 0 +
Well 8800GT beats GT 220 in games by a significant margin,it has 122 StreamProcessors compared to 48 of 220
Reply to Maziar
A GT220 should be slightly faster/better than a 9500GT which can actually game quite well so long as you like either older games (2005/6 era and earlier) or don't mind turning things down a bit (lot). I run mine at 19 x 10 and it handles that surprisingly well so a GT220 might not be that bad if you are not really gaming and to that end I've put my money where my mouth is and ordered one earlier today.
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
There are 1063 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
