Solved
Not sure what sound card I should get...
  • Sound Cards
  • Speakers
  • Components
Last response: in Components
December 26, 2009 11:25:03 PM
or if I even really need one haha. I just got the Altec Lansing VS2521 2.1 speakers for christmas, and i'm using on board audio right now. Idk what exactly the on board is but I know it's only 8-bit.
The sound right now from my speakers is pretty good but it sounds a bit tinny or w/e the word is haha. i'm not sure if that's just the speakers or if it's because I don't have a sound card.
anyone care to help me out? if any other info is needed just let me know. if i do need a sound card, i really don't want to spend more than $50.
More about : sound card
December 26, 2009 11:26:40 PM
What kind of motherboard do you have? List your system specs please.
m
l
December 26, 2009 11:29:35 PM
ah sorry haha. well it's for a new build that i'm putting together. i'm gonna have it around the end of jan. or beginning of feb. this is what it's gonna probably be:
CPU
AMD Phenom II x4 955 3.2GHz B.E.
Motherboard
Gigabyte GA-MA770T-UD3P
Video Card
Sapphire Radeon HD 5770 (Juniper XT)
RAM
Corsair XMS3 4GB DDR3 1600
Operating System
Windows 7 Home Premium 64-bit System Builders
m
l
Best solution
December 27, 2009 12:03:58 AM
Judging by the Newegg reviews of your motherboard, the onboard audio is pretty good. Make sure your speakers aren't the problem, or an improperly set equalizer in your media program. (you can check the speakers with a good mp3 player)
You can spend $30 to $50 on a decent PCI or PCI-E x1 sound card on Newegg, but unless it really bugs you you're probably not going to see $50 worth of improvement.
December 27, 2009 2:33:05 AM
alrightyy thanks!
m
l
