Hi
Thanks to some help I received on these boards, I recently built my first system and it seems to be working pretty good so after a week.
However, I really need some help or a pointer to the right article on how to set-up my motherboard as I am hearing a random single, very short, beep from the system speaker when in the Windows 7 64 bit OS.
I have googled this and see a few reports but no definitive solution, except maybe the settings for ram etc need to be right (someone mentioned about setting memory voltage to 1.64 v, and here is where I have questions based on the components I am using).
The beep is sometimes accompanied by the fan speeding up momentarily and sometimes (mostly) not. The beeps can be 10 minutes apart and sometimes 2 hours.
I am monitoring temps and they aren't going over 28° when doing office type stuff, and when light gaming, not above 45°. The system posts fine, with the single beep. I updated the BIOS to F8 with no problems.
I was hoping to set some of the BIOS settings up rather than use AUTO for everything. I have loaded optimised defaults in BIOS after revising to F8 but don't really know what settings I should have in there.
I especially need some help setting up the RAM because I bought stuff that says it is 1.5v because thats what I thought was right for this board. But who knows, maybe I could or should be running it at a different voltage, etc. Open to offers !
So, my components on the board are:
* i5 750 CPU w/ Hyper 212+ cooler
* 4GB kit (2GBx2), 240-pin DIMM, DDR3 PC3-10600 memory module CT2KIT25664BA1339 http://www.crucial.com/store/partspecs.aspx?IMODULE=CT2KIT25664BA1339
* Sapphire Vapor-X 5770 GPU
* OCZ ModXStream 500w PSU
* Edimax EW-7128G Wireless LAN PCI Card 802.11b/g 54Mbp http://www.amazon.co.uk/Edimax-EW-7128G-Wireless-802-11b-Ralink/dp/B000KLNRBS/ref=sr_1_5?ie=UTF8&s=electronics&qid=1269891826&sr=8-5
* Windows 7 64 bit OS
I'd appreciate any advice - either "go here, and read this", or basic instruction about what basic settings to go with to run without beeps.
Frenchy
Frenchy
