Closed Solved
XFX 5770 artifacts problem
Hey im running a xfx 5770 and the thing is just recently im getting artifacts and temp is around 39-42. Well what i found out so far is that if i uninstall and run driver sweeper theres no artifacts at all but the moment i download and install AMD cataylst 11.12 i get artifacts on reboot just on the screen i log in to windows.
So im wondering if you guys have any possible ideas of what it can be?
I never dowloaded or changed anything prior to this happening.
6 answers Last reply Best Answer
More about 5770 artifacts problem
  1. Try with older drivers. Have you OC-ed your gpu?
    p.s What kind of artifacts, during gaming, or in windows operation system?
  2. its happening with older drivers as well. and right now the artifacts are so bad in windows i can barely seen anything.
  3. Best answer
    As long as your temps are fine, PSU is adequate and you've tried drivers that worked for you previously, it sounds like your graphics card is dying. You seem to be saying that it keeps getting worse - this is indicative of a dying card. Luckily XFX cards have great warranties.
  4. In ccc setings turnof ati overdrive and in gaming select aplication controled, it helped me
  5. Best answer selected by jlang129.
  6. This topic has been closed by Mousemonkey
Graphics Cards Overclocking
