Pci sata controller card help
hobbyaddict
18
Hello All, I need help in configuring my pci controller card.
older Dell Dimension 4550
120 gig IDE Drive
adding Silicon Sata 3114 controller card
adding 2 seagate 1 terabyte drives
Upon boot up system hangs when drives are plugged in the card.
If I boot, then plug in the sata drives to the card, the drives are recognized?ALL works as needed.
Goal
I want to boot off the IDE, use this for the op system. Store all our valuable data on #1 sata and backup data with #2 sata Raid is not necessary I can use back up software to back up folders required.
I need to get this to follow through the boot sequence.
Please let me know if you need any additional information.
I have the second primary drive set to auto in bios, it will not reconize the card/harddrives? hardware unknown.
Thanks
