Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Building my 1st system : problem with rear i/o panel
Forum Homebuilt Systems : General Homebuilt - Building my 1st system : problem with rear i/o panel
Hello.
I have a quesiton you are likely to think is veeerrrryyyyyy stupid.
You see, I'm building my first system ever and it's not a piece fo cake.
My specific problem is with the rear I/O panel.
I have the Spedo advance case from Thermaltake and
the ASrock X58 Extreme motherbord.
For the file of me, I don't know how to install the rear I/O panel (the cover telling you which plug is what) that came with the mobo.
I have tried several things already and I damaged the thing in the process ( a couple of tiny metal pieces have broken). Documentation of both product is completely useless on this problem.
I'd be most grateful if you could help me with the procedure.
Thanks a lot,
Sykurmoli
Sponsored Links
OK, SO I have sort of solved the problem but have the solution brought other issueS.
I found out I could just clip the panel cover from the inside of the case.
The problem I have now is that, the actual connections are about 1/2 a centimeter off. I mena a USB connection should pluunge 5mm into the panel before reachin ght actual USB port.
I suppose this is because of the very thin metal strap that are pointing from the panel inside the case, and are holding back the actual connection.
Was I meant to simply cut off those straps ?
Thank you in advnace for you help,
Xavier
Reply to sykurmoli
(Sorry to answer my own post again, but the forum always tells me I'm not allowed to edit my messages.)
Actually, it seems like a problem with motherboard placement rather than just the tiny metal tabs from the the I/O shield.
It is just as if my mother board was too far from the back of the case and also a little bit too close of the right panel. (the actual connections are "deep" inside the case and also slightly off to the right than the place they are supposed to be if I see the I/O shield.
This means dust can easily enter the case this way quite easily.
Is this normal ? If not, what have I done wrong ?
Thanks in advance,
Reply to sykurmoli
- 0 +
the cover pops in from the inside of the case, don't worry if some of the little tabs came off that's no big deal. As to the alignment look at your motherboard tray there will be many holes in it so that you can fit various types of motherboards you will need to figure out which holes to put the standoffs in in order to make it fit correctly
------------------------------ E8400 : GA-EP35-DS3L : mushkin 4GB DDR2 800 : HD 2600PRO : 450W ATX12V : Windows 7
Reply to 505090
Thanks for your answer. Unfortunately, there aren't so many holes in the case. Just those to fit ATX and those for mint-ATX (in many cases, the holes are shared).
I'm pretty sure I used the right holes, because otherwise, the actual I/O wouldn't be 0.5cm off, but rather 10 cm.
However, by nudging things a little, I have now come to an alignment that is not perfect, but that I can live with.
Ports are now reasonably easily accessible, and the only problem is that the thing is not a great anti-dust shield, but I suppose I just have to be efficient with my room cleaning :o) Come to think of it, it's not much worse then what I had with my latest system, from Packard Bell.
Thanks for trying to help me, and for reassuring me about the little tabs.
My system is now 98% working (only one front USB port not respondiong and some problem witht he sound card, a sound blaster X-fi titanium, recognized by windows but not by creative's own control panel)
Xavier
Reply to sykurmoli
There are 908 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
