I recently bought a refurbed X58 SLI LE board as my main board is going through rma.Here is my build:
i7 950 with apogee gtz
16gb g.skill
120gb vertex 2
xfx6950 with EK copper block
X58 sli le
corsair 850
1tb
250gb
mcp655
swiftech micro res.with silver coil
480 rad 120mm nidec betas at 3200rom each on a push
Now my previous board was a gigabyte ga-x58a-ud3r. i had it going from res>pump>rad>cpu>gpu>res. using primochill 1/2ID tubing. Also if this may help, I RMA my cpu as i could not figure out if it was the cpu or mobo gone bad. anyways intel sent me a brand new chip.
so i have the same loop going in with the sli le board except in trying out the feser tubing 1/2ID.
My temps with the giga board and older cpu were around 32C and my graphic card 33C.
with this sli le board, my temps in real temp show 56C-62C and gpu at about 49C. I reseated the cpu and reapplied mx4 twice.
now on the board display, it reads at about 48C.
tubing is at same length at the other tubing used for the giga board.
Any thoughts.
16gb g.skill
120gb vertex 2
X58 sli le
corsair 850
1tb
250gb
mcp655
Any thoughts.
