Hi,
I've been having a very annoying problem with my computer recently where it will freeze every short while. It freezes and the hard drive access light comes on. After the light goes off the system will unfreeze. Most of the time I can still move the cursor around and bring opened programs to the foreground, but it seems like anything that requires access to the hard disc will get stuck.
I'm wondering if the drive is dying. I've turned off the paging file and I have 3.5 GB of RAM. I've run antivirus and antimalware scans so I don't think malicious software is the problem. The OS is Windows 7 32bit Ultimate.
This is a new issue, and the drive is old. I've had strange problems before when the power supply is going bad, but I don't think I've had this specific issue. I haven't tested the power supply yet though.
Also, the other day I got the first BSOD that I can remember. It happened when I was running an antivirus scan, although I'm not sure if that matters.
I just checked the Event Viewer and there are a bunch of atapi errors (Event ID: 11).
Any thoughts? Thanks!
