Solved
Speed?
Last response: in Memory
That is just showing all of the different speeds that are preprogrammed into the ram/BIOS. Go over to the memory tab to see what your system is currently running at.
Well, the effective ram speed (what people often refer to) is twice the DRAM frequency:
539.5 x 2 = 1079
(Which is expected, most modules/BIOSes default to 1066)
And latency is 7-7-7-19-1T.
And Triple channel is enabled and working.
To get RAM voltage, you'll need another utility such as HWMonitor.
Related ressources
Best solution
Not hard. The ram's website (or box) should tell you its voltage and timings for its rated speed (1333). Just enter them in the BIOS and test with Prime95 and or memtest86+ and you're set.
Ask the community
