How to solve Error system fan speed critical threshold
1 answer Last reply
More about solve error system speed critical threshold
  1. Im guessing the fan in question is either the HSF fan or a fan connected directly to the motherboard.
    Depending on the make of motherboard (either thake the side of the case off or use CPUz to identify which board you have) then you can overide the alarm or change the speed setting in the BIOS at which the mobo is set to warn you or a fan failure or running at a high / low speed.
CPUs Fan Speed
